Lenny and Louise
- May 2, 2013
- C-302 C
- Then Again
The last couple attempts to run the pump have been frustrating. The pump works for a few minutes then shuts down. If i turn the switch off and wait a few minutes, then turn it on, the pump starts again, but shuts down again. No apparent pattern to how long it runs or how long it takes to "rest up."
The first thing that came to mind was heat. However the pump should not get hot in a minute or two of operation. Nor does it sit idle in the on position. I rig my hose, turn on the pump, and start discharging at once.
I am not resetting a breaker, just turning the switch off and on. As i understand, the pump is protected by a fuse and there is no breaker in the circuit.
Thanks for the help!
