Hydraulicjump
- Feb 10, 2011
- C-30 CB
- FMLT2911F415
- Non-Fluid Motion Model
- Necky Looksha VII, Liquidlogic Remix, Jackson 4Fun
- La Barka (2015)
Tugnut Braintrust,
Have any of you used this swivel outboard motor bracket on your inflatable or rib?
http://adventuremarine.ca/dinghy-access ... acket.html
We are thinking through how to avoid having to mount and remove the motor each time we launch the dinghy from the Weaver davits. Asking this because I would like to consider a slightly heavier motor (6hp) rather than the lightweight 2.5 hp or Torqueedo. I still don't trust the Lehr motors based on the numerous bad reviews (too bad...good idea, though). The problem with this motor mount is that you can't rotate the engine to vertical because the shaft runs into a tube. But the manufacturer anticipated that.
The alternative is the Weaver Bracket, but it has a Rube Golburg look to it and would require removing the patio rails.
https://www.weaverindustries.com/index. ... nghies.htm
Holler if any of you have experience with this.
And the alternative would be to lose the patio rails and go with a Hurley Davit system like Jim Favors uses--which keeps the rib flat. But the propane box uses up a lot of space and means you are sticking this dinghy way out behind the swim platform.
https://hurleymarine.com/shop/dinghy-da ... ghy-davit/
Input welcome.
Jeff
Input welcome.
Jeff
