RT 25 OB Bridge Clearance
The Breeze
Catalina 380
Very grateful if someone can tell me what the mast-up bridge clearance is for the RT 25 OB both with and without RADAR.
Thanks!
Hi there,
You will need to measure that for yourself. There is no way that we can give you a clearance number, as it all depends on how your boat is loaded out. You can understand the liability issue as well (But you told me...!) 😉 Good news is that it's not difficult to do. You or a helper can simply stand on the cabin top and hold a tape measure at top of mast level and have someone else spot the tape measure as it touches the water surface. That will do it. Hope this helps.
Cheers,
Ralf
