HappyPlace
- Feb 11, 2016
- C-302 SC
- FMLT3133A414
- Happy Place
I have a tiny leak in the cave that appears to be coming from a screw holding the rub rail on the port side, where the gunwale water drains off the ledge. I currently have some white vinyl in place to redirect the flow, temporarily abating the issue.
Should I:
a) remove the single screw and put some marine caulk on it, then reinsert?
b) remove the single screw and put some 3M 5200 on it, then reinsert?
c) wait to remove the entire section of rub rail when pulled for the winter and perform (a) or (b)?
d) other suggestions or recommendation?
Any advice is always appreciated!
Al Sr.
Should I:
Al Sr.
