Full_O_Fish
- Mar 21, 2023
- C-30 S
- FMLC3014I415
- MYST
I can unequivocally state that the ECU12 meant for the retrofit/mechanical system works with any reversing pump as I have both installed many systems this way, and run one currently with over 2000hrs of use on my other vessel. Garmin will generally tell you that it will not work because again they want to sell you a smart pump or another 1.2 if you ever have an issue with yours. The reason they will tell you it won't work. It's because they do not want you cutting the plug off the end of the 1.2 drive cable.
And yes, you would just leave the feedback plug from the 1.2 unplugged as that is just an encoder to give the ECU10 a reference for how much port or starboard the drive has pushed fluid rather than a true rudder reference like the ECU12 requires.
You're correct, but if you already have the reactor 40 CCU that you will only need the ECU 12; however, you will also need the $20 drive unit power cable for the ECU 12 as it does not come with it.
