BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
I was in the process of yearly inspections of Rudder log, trim tab reservoir fluid level, deck drain hose connections and stern thruster. Finishing with greasing the rudder log. I noticed that the bonding wire was no longer attached to the rudder post. The factory installed bonding wire was too short and eventually severed. Assuming that the wires are precut before installation my boat may be a one off with this issue ( one time measurement mistake) or there may be many with the same issue ( production measurement mistake ). The rudder is the largest metal component in the water. One of the primary purposes of the bonding system is to provide a single point-of-access to protect multiple structural metals of the boat from corrosion, via a sacrificial anode. If it's not connected its not protected.I am posting a few pictures of the as found and repair. I used 6ga wire instead of 8ga to add strength to the connection.
