Running an AC wire up to the breaker…
dougxn
R-27 Classic
Celtic Sun
Has anyone run an AC wire up to the Ac panel next to the front of the wheel house? 2015 R-27
I am adding another charger for my lithium battery and want to properly have a switch for it up front.
Q: what is the best way to run the wire or perhaps just make another panel in the back…
Q: how is the panel mounted- do I need to get behind it to remove the face?
Thanks !
I ran a low voltage to the helm. I also left a drag line from the engine compartment to the helm for future pulls. Removing the refrigerator and stove helped. Using a snake and doing it in segments is the way to go, as well as having a helper. I ran the line under the floor of the head. Then into the stove compartment back wall. Then behind the refrigerator along the hull. You can remove the electric panel by removing four screws in each corner under the covers and access all the breakers. It wasn't to difficult.
Thanks! I will give it a go this week.
