Rust on Helm door
Irish Mist
C-288 C
FMLT2922K011
Hi All
I am noticing a little bit of rust bubbles under the paint on my helm door below the plastic handle ( 2011 R29 ) As anyone addressed this and if so how did you fix it? I will need to sand and repaint, but trying to see if anyone has done this yet and if there were any surprises.
Thank you
I have the same thing... a little bit on the cabin door and the helm door. None on the windows. I don't think it's rusk, moe likely aluminum corrosion. Haven't really researched a good method to tackle the problem because it's not that bad. But I can't see it being anything more than sanding down the corrosion, priming and a little touchup paint in a matching color.
We have the same bubbling on our helm sliding door and the cockpit door on 2011 R29; the paint is holding up and not flaking off and until that happens, I don't plan to do anything. No signs of this issue on the windows.
Irish Mist":5l3xvx5x said:
For those interested here is the paint to match the door. Amittay from at the factory was kind enough to find it for me.
https://www.lvppaints.com/RAL-8008-4-Oz ... Paint.html
Thanks for posting the info. I wonder why we have issues with the door and not the windows? My boat is 11 years old and the window frames are perfect.
