Safety Gear - Lets Discuss
tranmkp
Id like to know how everyone has approached safety with their boats -
things like...
How much line do you carry onboard?
Throw-able Life rings
Signaling equipment
I carry Aerial Flares, Handheld Flares, Orange Distress Flag and an Orion Strobe light.
For lines I have:
One 35' 3/4" dock line,
Three 25' 5/8" dock lines,
Two 15' 5/8" dock lines.
I don't carry a life ring however I have an auto inflate PFD for each person on board and it is mandatory for them to be worn.
I have two throwable cushions.
I have 25' Chain with 200' 5/8" rope anchor rode.
I have 50' 1/4" line
When I add a dingy I will add 50' of tow line.
Handheld and installed VHF
Garmin 86sci for distress calls and back up navigation.
EPIRB
Boat US tow insurance
The list is endless
- portable Whale pump mounted to a 12” x 12” board.
- water ski flag for emergency waving
- SOS banner
- wide variety of tools
- all kinds of tape, zip ties, flashlight batteries, etc
- foam and wood cones to plug holes (marine store)
- note book of boat operation tip sheets on everything you can think about
- phone charger
- spare sun glasses for your friend that thought it wasn’t going to be that sunny!
You hope you never need a Whale pump, yet I had it one week before I was pumping as fast as I could in an emergency. I am glad I went for the 1.5” dia. Buy hot tub hose from Home Depot or Amazon. One of the best investments I ever made that paid off so fast. $50 hose, $150 pump, $5 hose clamps. Some people say mount it on the boat permanently. That does no good when your buddy’s boat is sinking and the two boats are traveling together.
Master
Would you care to elaborate on the Whale Pump Incident?
I am not 100% sure of the cause
- last 10 miles of a 200 mile five day trip
- calm sunny day
- cruising 10 knots with R29 300hp 2017
- engine started to hesitate
- lifted up engine door, one big flood
- enough water to affect electric or engine air intake
- scary as hell!!!
- pumped out all water
- checked everything I could - no cause found
- engine started right up and ran fine
- made it home no problem
- nothing leaked
- only thing I could figure out is MAYBE boat wake was causing a spray on the dingy like a garden hose and then going under slot on folding seat flooding cockpit
- I had a 24” buoy ball at edge of swim deck which may have magnified the spray even though it was above water line when boat was not moving
Things to do or know;
- turn high water alarm on all the time at helm. This might have been off. I did not know about it
- make sure both pumps work at right volume, by dumping five gal buckets of water in bilge
- clean debris from pump with boat wash down hose
- unsnap pump an clean inside once a year. I found hair and a loose mfg label partially plugging pump
- pumps are rated 4x gph than they actually pump
- I have Johnson pumps that look so small, they wimpy like an aquarium pump
- get familiar with how often and how much water it takes for pumps to go on
- check bilge several times on long days
- fwd pump is hell trying to remove. I got it out with two very long needle nose to clean it. It would be torture if I had to rewire a new one.
- it is really easy to remove the cartridge, ONCE you figure out the trick. Experiment with aft pump
- some people say it could have been an air pocket in pump. A loose mfg label inside aft pump wouldn’t help that. It would take a lot of water in bildge for fed pump to turn on at 10 mph boat angle.
- justification to wear your inflatable life jacket - I had it on the whole time.
Here's a good video on putting together a "bilge pump in a bucket" for emergency use. https://www.youtube.com/watch?v=3cnJgRztYpY
Courtesy of the Skaggit Valley Community College Marine Maintenance program (lots of good videos). I can't say I've assembled my own "bilge pump in a bucket," but it's on my never-ending "to do" list. Probably should make it a higher priority.
Gini
I am new to this website, but I was in the Coast Guard Auxiliary for 26 years and "assisted' 256 boats that I actually did the paperwork for. Here's what I (still) carry:
legal requirement of aerial and handheld flares, and extra aerial ones left over from years past. They last a lot longer tha the 40 months written on them. however, make sure you have enough that are within the code dates to be legal.
Make up a piece of 1" PVC with a cross pin so you can put the handhelds into it and have them held overboard. The slag is hot and can start a fire in your boat. When firing an aerial one, hold it above your head. The d**n gun is plastic, and if it fails getting your hair (or hat) singed is better than your eyes getting burned. Orange flag, and smoke flares, in addition
Emergency pump. The "bicycle pump" style manual is good for bailing your dinghy. You get 6-8 strokes to a gallon. You will run out of energy before you run out of water. Buy a 750-1000 GPH rule or similar. Put about 15' of flexible hose on it, and about 20' of power wiring. Terminate with small battery clamps. Toss the pump into the bilge water, hand the hose overboard, clip the wires to a battery, and its pumping. The wooden plugs discussed above is a good idea. I got a kit with 4 different sizes using soft wood back years ago from Defender. I was relatively cheap.
Fire extinguishers. For the 25 you need a B-I, larger 2 B-I or a b_2. B-I is 2.5# dry chem, and B-II is 5. My extinguisher is a A2, BC40 with 15#. I read too many reports where someone was using a B-I and they said it was just beginning to put out the fire and it ran out....note: what to do with an extinguisher which is out of code date? Start a fire in your barbeque grill, and have each member use it to put out the fore, or coordinate with your local Fire dept for then to help you. For the purchase price even of new cheap ones, you cant get that kind of training any cheaper.
First aid kit: You bought a $9.98 at Wal mart and you think you are protected? Wrong!. Go to a fire station near the water which has paramedics. They will tell you what to have and believe me, the "kits" do not come with them. Like: Have you been stung by a Jellyfish? Wash in sea water, wear gloves when handing the tentacles, and rinse with ammonia, Yep, the same stuff used in cleaning the hose, even windex. I bought some professional strength stuff at Home depot. I think you get the point. My kit is in a medium size gym bag. Buy a book on "marine First aid". I found one at west marine for $10. O r take a red cross course. That are taught by paramedics.
Towing gear. Unless you have been trained in assist towing, do not attempt it. It looks easy, but it is dangerous for the untrained. Look at a Coast guard 44' boat. There is a chain link fence behind the helmsman. If the cleat on the towed boat comes loose, its coming at the back of the head of the helmsman. Cleat vs Person---- cleat wins
radio; Nothing else but an installed VHF marine radio, and antenna. handhelds do not have the range. cell phone, ixnay. Scenario. You are in a large lake and a person aboard has a medical emergency. SO you whip while all this is going on, I an fishing a quarter mile from you, and my fishing buddy is an off duty paramedic training officer, and my radio is turned on..... A simple mayday (Yes, medical emergencies are a mayday) and many people hear it. Help may be close.
EPIRB/locater?
Do you boat offshore more than say, 10 miles? The C G radio system is set for 20 miles to a 1 watt radio. And have a handheld waterproof radio as a back up. (I do)Other things: when i boat alone, I use the disconnect lanyard. make sure there is some kind of ladder/boarding system that can be initiated from the water.
Non-swimmers wear lifejackets. Same with children. many places that sell toys have children's jackets with cartoon characters on them. Less stress to get them to wear them. When the Captain says for all hands to don them, there should be no argument. Like a parachute-- don't do any good unless you are wearing it. The jackets should have a mirror, whistle and a strobe lamp (or waterproof flashlight). When being looked for in the water, your 1' diameter head is hard to see from more than a few hundred yards. You need a multi-media show at attract attention. In the keys I heard a radio request to look out for 2 missing divers. About 1mile from their dive site they flagged me down. They were 300 yards away, in a 2-3' sea. Without their waving and shouting, I would have went way past them.
Maybe I over do safety things, and yes, I understand we have a 25' boat, but I am alive to write about this after 50+ years of boating, offshore fishing (usually 20+ miles offshore) and ocean scuba diving.
If this is overdoing it, let me know.
