knotflying
- Jul 25, 2010
- C-28
- FMLT2731J011
- Non-Fluid Motion Model
There was a thread a while ago regarding the screen rusting on the port hole at the head. I had the same issue on my 5 month old R-27. The screen rusted to the point to where it was starting to seperate from the edges. I removed it from the brass ring by heating the solder around the perimeter and then smoothed out the edges around the ring. I then purchased plastic screening and cut a square larger than the brass ring. I laid this on top of a larger piece of plastic wrap. I placed a very small bead of silicone caulk on the solder side of the ring and then pressed it firmly on top of the plastic screening. After letting it dry overnight I peeled the plastic wrap away from the assembly and then trimed the outside edges around the ring to cut away the excess screening. Below is a picture of the finished product. Hopefully this will hold up longer than the original. below is a picture of the finished product.
