Andrew Custis":11x1p9o8 said:I couldn't agree more that the scupper screens (at the cockpit side) should be immediately removed. The smallest amount of debris, dog hair etc.. can plug and make a mess out of the boat. I tell others to remove and frequently take a hose and flush them out. There should never be a screen on the outlet side. There should be a rubber flapper on the outlet side and that is it.
Thank you!
Andrew Custis":3kk7ss0l said:Hello,
Yes, they are exactly what you describe. Pop them out with a small screwdriver. I usually plug one of them with a rag and force water through with a hose on each end. I see barnacles grow and clog these all the time. Keeping them clear will make drainage much better!
Best regards,
