Capt’nKarl
- Feb 22, 2013
- C-242 C
- FMLT2330I718
- Non-Fluid Motion Model
- Previous R-21EC
- DRAGONFLY
Greeting fellow TugNuts,
I seem to be having a decrease in water flow from the outside engine exhaust. Although the engine temperature alarm has not sounded I’m concerned about build up in the heat exchanger causing this low flow. The impeller and water pump belt are new and seem to be working fine. The heat exchanger has never been removed or “flushed”. I’ve seen several YouTube videos where the exchanger has been cleaned without removing it from the engine by running Sea Flush through the system and letting it sit for 4 hours. Doesn’t anyone have any experience using this stuff and if so does it work? Any information would be appreciated.
Karl
Karl
