Sea strainer gasket?
jswhal
Cutwater 28
Sea Glass
Is there supposed to be a gasket or O ring on the C28 with the Volvo engine? There's not on mine. It's just a plastic lid.
I am posting a picture of the sea strainer in my C26. If this is the the strainer you are referring to the gasket is installed on top of the housing. Here is a picture and a description of the strainer. If this is the stainer used in your C28 the parts can be purchased at Marine Hardware, Or call Richard at Ranger Parts department.
https://www.go2marine.com/docs/2/0/7/0/207044F-f.jpg
Marine Hardware
Raw Water Strainer ▪▪Design ensures a firm mount to the engine stringer and allows full 360º rotation of the top housing ▪▪For left and right hand engine installations ▪▪H: 13.68" xW: 8.25" , MHI SEAS-UM-200SM Parts: MHI SEAS SCREEN-2.000 Replacement screen MarineHardwareSeaStrainer Flow-through design allows water to tumble horizontally across a stainless steel screen where debris is chopped into small pieces. These pieces, once small enough to pass through the screen, can easily pass through the engine'swater systemwithout harm and be exhausted overboard. ▪▪Made of precision machined bronze ▪▪Clear acrylic lens allows for quick inspection ▪▪Drain plug simplifies winter storage ▪▪ Inlet: 1-1/4" hose ▪▪Outlets: 2 x 3/4"NPT& 1 x 1"NPT MHI SEAS MPNPT DOME* Parts: MHI SEAS-3GASKETS 3pc. gasket set. MHI SEAS-LENS-DOME Domed -
Thanks Brian, that looks like it. Will get in touch with Richard.
