searchlight
drspinazola
C-24 C SE
FMLT2152B707
Toot
How does the searchlight on a 2007 21'EC turn on and operate?
On a 2010 21EC you first turn on the power from the switch panel by the shifter. On mine it is the first switch, closest to the shifter. The light is then turned on and pivoted up and down, left and right etc from it's control box which on mine is located on the shelf above the steering wheel which also has the VHF radio on it.
Dave
Once you turn the power on at the breaker panel, push the "F" button on the search light control panel for "flood" and the "S" for "Spot".
My 2007 21EC has a remote control.Once the main power switch is on you use the hand held remote, which has 4 arrows for direction. Just have to be carful when it swivels past 90 degs (from straight ahead)it hits the trumphet horns-- depending on what the vertical tilt may be! RB
