bails023
- Jul 31, 2013
- R-21 EC
- FMLC2815H314
- Non-Fluid Motion Model
- Cutwater 28
- First & Last
I have a 2014 C-28 and when commissioning the fresh water system noticed a substantial leak at the bottom of the hot water heater (HWH). I had noticed a little wetness in-front of the HWH over the years however today there was a steady stream of water when the fresh water system was pressurized.
Each winter the fresh water system has been completely filled with antifreeze and I have never had any freezing problems.
Removal of the HWH (not a fun job) revealed that the weld for the heating element connection had cracked (see photo in album - weld crack - light line in about 30% of the weld).
Have anyone else experience this type failure? A quick web search identified a number of F-600 weld failures however, the description was not clear as to where the weld failure occurred.
I tend to think that a weld failure (even on a four year old HWH) is a "manufacturing defect".
Does anyone know if it is worth it to try and have the weld repaired or is it better just to buy an new HWH?
Thanks.
Thanks.
