DICK VON ROTH
- Apr 26, 2009
- C-248 C
- BUSTER
I seem to have a problem with my cockpit self bailing feature. First I have a factory installed genset which makes the boat list to port. My scupper which is located port side aft near transom. It seems that the scupper drain hoses are lower than the main drain so the water must run uphill to escape. Does anyone else have this problem? The boat was built in 2007. If there was a l type fitting which was shorter than the white pvc one i could raise the hose somewhat which would help but I dont think this "L" fitting can be modified because of the composite material it is made of. Anyone have a way to solve this problem.
