Phil Nersessian
- Feb 24, 2016
- C-24 C
- Non-Fluid Motion Model
- Cutwater30LE
Not sure if this is the way to deal with this issue or not, but here goes.. I took delivery of my new Cutwater 30le cb on Weds. it was delivered close to empty so we put in 180 gal. at the gas station before launching(I filled my diesel dump truck there 2 days prior w/ no issues). I put about 7 hrs on the engine that day and a couple more the next. Yesterday the Garmin said there was a sensor issue when it started, then the Volvo readout stated there was "water in the fuel". I followed the directions in the Volvo manual and drained about 4 oz. of what appeared to be clean diesel out of the water separator. I ran the boat about 5 hours Sat. w/ no apparent ill effects(I didn't run the generator just in case). The "water in fuel" light is still on at the Volvo read out. The dealer is about 300 mi away (Hamlin's in Bangor, Maine). Any Advice? Can I still run the engine? Drain separator again? Does it need a new sensor? Add an additive?Thanks, Phil
