Shore Power 1 Not Connected
fmickey
C-302 SC
GooseFeather
The meter shows Shore Power 1, but none of the AC switches on 1 are powered and the charger is not functioining. Apparently the AC Panel schematics are top secret.
Will need a little more information. Are you seeing the green light at the Shore Power one switch on the AC panel?
Is your inverter switch turned on? Shore power passes through the inverter/charger, so if the switch is off, that side of the AC panel won’t receive power from shore, and the charger won’t turn on. If you're still not getting shore power with the inverter switch on or if the charger still isn’t working, then the inverter/charger may be faulty.
The switch is on. This happened with no manual intervention. I was hoping for a fuse or breaker, but that seems not to be the case.
