SHOWER
ESCAPE
Corsair F 27
ESCAPE
Has anyone installed a "hand held" shower in or around the swim step, or cockpit, as an alternative to showering in the head ? If so can you give me details as to location.
THANKS
Bob Messmer
R 25, hull #21, 2007 year
ESCAPE
Bob: I don't know about your 25 but on our 27 we simply take the screen to the port window out and run the shower head thru it to the cockpit and shower their when we're on the hook. Until I figure out a replacement faucet handle that has a on/off button on it it takes two people to turn the water on and or off, without running in and out of the boat.
Jim
Jim,
My arms must be longer than yours. I am able to set the water to the proper heat while in the head and then I turn the lever off. I then go outside and am able to reach in, grab the shower head out the window and lift the lever. I believe Gerry from "ALTO" also found a kitchen sink sprayer that he uses, so he can leave the water on and just spray away by pressing the button on the head. We also bought some special salt water soap (http://www.savondemer.com/ ) that works great and I was able to stand on the swim platform and use the raw water hose. Granted we were in Florida so the water was a bit warmer than it is up here in the Northeast. In any event it worked great and I felt as clean as a whistle, but I'm not sure if the dolphins and turtles appreciated seeing me on the swim platform au natural.
My R21 does not have a shower, but my previous boats and RV's had a hand held shower head that had an on/off button. You just set the water temp with the faucets, then use the on/off button to conserve water. You can find them at most RV stores.
For something a bit easier to find anywhere, Joy (dishwashing liquid) lathers in salt water, too. It's a staple for long distance cruising sailors. Gets your dishes clean, as well as you! 😀
On YOLO, (R-27), we installed a unit purchased from SSI just to the right of the propane tank locker.
Mike from Knotflying is right. Here's what I previously posted as a solution to how to shower in the cockpit, or on the swim platform:
1. Remove round screen from port hole in bathroom. Set aside as spare for use when other screens rust out. Use sky light with screen installed to vent.
2. Replace shower head (looks like a telephone receiver) with an On/Off switch model. These cost about $8-13 and are available in RV stores but not stores. They come in white, silver and biscuit colors. Buy a silver one. http://www.rvplus.com/phoenix-products-hand-shower-head-classic-bisqu-9-342b.html
3. Buy a Thetford 36670 Spray Station holder for $6. It sticks by suction to the fiberglass wall under the porthole in the cockpit. They come in white and silver, buy a white one to match your fiberglass.
http://www.americanrvcompany.com/Thetfo ... 4445.html#
4. Enter head and set shower water temperature where you want it, then turn off water flow at the shower head.
5. Snake shower head out the porthole. Exit head, open big glass door, and sit in cockpit close to dangling shower head. Insert shower head in Thetford holder (which should have been previously affixed to the exterior wall under porthole; refer to instruction #3 above as needed). Turn on water. Shower. Rub vigorously! Turn off water while soaping to conserve.
6. Hose hair, follicles, skin fragments and other debris that falls off your aging body down the scuppers. (remember to clean scuppers once a year, or just before you sell the boat.) For very large fragments of mung, remember you have a powered raw water washdown nearby.
7. When done, reverse process and drop your new shower head into the existing holder inside the head, which, is still dry and hair free. Unsuction the remarkable Thetford folder and put in a safe place.
8. If you want to shower on the swim platform rather than in the cockpit, purchase a shower hose extension(s). They come in 6' long lengths so you may need two.
9. The above procedure, while complex, does lend itself to having a cold beer sitting nearby during showering to ease the process. Leave cap on bottle to prevent inadvertent beer dilution during showering. Feel free to print, laminate and affix this step-by-step guide in the cockpit to ensure steps are followed in proper sequence, if several beers are needed to complete process.
10. Remember my wife's rule: Shower every Saturday, whether you need it or not!!
Detailed instructions, like above, for use of a composting head will be offered later. WARNING: these will not be for the faint of heart! Photos may be included!
I just did it this spring. I will post the details/pics over the weekend.
Have you had time to post the details of your instalation ?
Bob Messmer
ESCAPE
R 25, 2007
Sorry. Putting in a lot of hours at work. I'll get it put up by Saturday.
