Side power remote receiver
F Farkel
C-288 C
Fmlt2905f213
Caldonia
Where can I find the SP remote receiver on a 2013 R29?
Hi,
The Side-Power receiver should be behind the main helm. Feel free to contact me if you have any further questions.
Thanks!
also you will need one of the aux switches on for the bluetooth connection to be energized.
All the components on the backside of the helm are either Garmin or Lewmar, no SidePower. But the good news is the remote worked after I turned on “ACCY 1” switch at the helm. I’ll keep an eye out for the receiver.
Thanks to both of you.
Glad your solution was simply flipping a switch. For future reference, the receiver is a small back box that is usually found directly under, but separate from, the thruster control toggles. Remove the four small triangular plastic covers at the corners of the toggle, unscrew and lift the toggle assembly out. A rat’s nest of wires will follow and the receiver is somewhere in that mess.
