Side Power Remote
Skennedy
C-30 S
Bobber
I’ve got a new to me 2016 R29S and it has a Side-Power thruster remote that had a dead battery. I can’t seem to find where the antenna is located so I can pair it angain. Anyone know where these are typically installed?
Steve
Hi there,
The receiver is located inside the throttle box, right below where the thruster joysticks are. You can remove the joystick panel by lifting the little triangular corners and removing the screws underneath. Then pull out the panel and you will have access to the receiver. Hope this helps.
Cheers!
Ralf
