NorthernFocus
- Jun 29, 2014
- Alaska
- Website
- www.northernfocusphotography.com
- R-25 Classic
- FMLT25910808
- Divine Focus
We're the 3rd owner of our 2008 vintage R25. Not knowing what kind of fuel hygiene habits the prior owners had and having a strong paranoia about fuel problems, I decided to clean the fuel tank. Well as you know that's easier said than done on these boats. So I set about designing a little fuel polishing skid. As I began to spec out parts it became evident that there was no real cheap way to do it. At least not for a robust package that could be easily set up when desired. Or left permanently installed. In the process of looking at parts and pieces, I ran across a simple solution. It was a bit more expensive than a do it yourself model but not unreasonable. Particularly considering the time saved.
The device is a Racor P510MAM fuel polishing filter. It is physically about the size of one of the 500 series turbine filters and has a pump built right into the top of the filter housing. It pumps 60gph though the filter. Elements are available for 2, 10, or 30 micron filtration. It comes with a marine grade switch for the pump and an installed WIF sensor but the detector is extra. It cost right around $500 plus another $50 or so for fittings.
The generator was removed from my boat by the previous owner but the fuel supply and return lines were still in place. They provided a convenient place to plumb up the polishing filter. I simply moved the supply from the outlet to the unused inlet port on the primary filter housing so fuel runs through the housing but doesn't have to pass through the 15gph rated element. If I decide to install it permanently the plumbing will be completely re-done.
So, anyhow, for any other clean fuel freaks out there, it's not a bad option. We'll find out tomorrow if it did NOT work. If it did, well we'll never know whether it did or if the fuel was already clean 🙁
