Hydraulicjump":by8inrti said:
Can I ask a dumb question of your solar power veterans? Why not add the thruster/windlass battery to the house batteries by simply hooking them up in parallel when you are on the hook?
Jeff
This is a good idea. I am making a permanent connection between the current house and thruster banks for just this purpose. I have been researching this and there is a trend toward a single bank for everything except engine start. As you say this provides 50% more AH. The current thruster bank is idle most of the time, why not use this capacity!
I had an inadvertant experiment that did just this. For the first year of ownership there was a short behind the battery switches that connected the thruster power to the house bank. This allowed the thrusters to operate even when the master thruster switch was off (not good). Whenever the thruster master was turned on the house and thruster banks were connected in parallel. A jumper cable behind the battery master switches that connected the house to the parallel switch had shorted to a lug on the thruster switch. Andrew sent me a longer cable to replace it, I was able to route it down from the house switch, across and then up into the parallel switch to prevent a recurrance of the short.
I am also installing a Victron battery monitor, this will provide a more accurate "gas gauge" for the house bank, now with three 90AH batteries instead of two. This monitors the voltage and actual current in/out of the bank to calculate AH in and out. It accounts for Peukert's formula where AH available is reduced at high current draw, and AH are increased at low current draw. An alarm can be set at a specific point (such as 50%) to warn you before you discharge too deeply. I will also know how much charge has been put back into the house bank.
Regarding windlass power after extended anchoring and a discharged bank, ideally you should not discharge the bank more than 50%, so it would not be an issue. The main engine will be running, the alternator is directly connected to the house bank and will immediatly start charging it. Worst case draw by the windlass is about 50A, and typical draw will be less (unless you use the windlass to pull the boat toward the anchor!) so even at idle the alternator should be able to provide a good portion of this, if not all. In a worst case scenario you could increase the engine RPM to get more current, the engine has a 150A alternator.
Another issue is charging the bank from the genset. My R27 has a 20A battery charger, this would take hours to restore a significant discharge, 50% of the bank capacity is 135AH. I also plan to upgrade the charging capacity to allow quicker charging from the genset. Another advantage of the three battery house bank is increased charge acceptance. A rule of thumb is bulk charging at about 15% of the battery bank capacity. 15% of 270AH is about a 40A bulk charge rate. I will also disable the ACR while charging from the genset to allow all charge current to go to the house bank. The engine battery would already be fully charged.
I will post pictures of my modifications when I am done.
Howard
