BaylorU
- Oct 23, 2018
- R-21
- Grace
Hi Y’all,
Curious if anyone would be willing to share some guidance on the addition of a sonar fish finder and/or AIS (receiver only is fine, but transceiver is better if cost is comparable, which I suspect it wouldn’t be) to the Garmin 5212 MFD.
I currently have (2012 C26) the VHF200 radio, 5212 MFD, and Garmin Autopilot (can’t remember which).
I don’t really see much need to replace the 5212 right now, as it’s perfectly fine. The nice thing is because it’s older technology, I can pick up used add-ons at significant savings. But I could use guidance as to A) what specifically is needed and B) what’s involved with the addition of them.
For example: I currently have the Garmin VHF200, which is a fine radio. However, I could upgrade it to the VHF212 and add AIS reception. My understanding is I could also then display AIS targets on the MFD with the addition of the VHF212? Will I need to add an add’l VHF antenna to achieve such a result?
Furthermore, is swapping out to the VHF212 the only option I have, or can I keep the VHF200 and simply add a black box solution such as the AIS300 (I think that’s what it’s called)? If I were to go that route, would I need another VHF antenna?
With whatever solution I end up with, I’d strongly prefer to avoid adding another antenna if possible.
To add a fishfinder, I’m guessing a simple black box and transducer is all I need? Where in the hull would I want to install said transducer?
Next question: do other brands of components play nice with the 5212? So could I add a Lowrance VHS with AIS, for example, and still achieve the same result as the Garmin VHF with AIS? Same for sonar?
And ONE MORE question, promise it’s the last one....current Garmin software is version 7.80, maps are G2 v2014.5 v16.00. I know I can do some research and figure out if it’s worthwhile to upgrade either, so I’m not asking anyone to do any work or spend more than a moment on this. But if anyone just happens to know off the top of their head, I’d be curious if upgrading either software and/or maps is something worthwhile given where I’m currently at, version-wise.
Thanks to anyone who took the time to read this, let alone reply! 🙂
Ken
Ken
