Source for R27 windshield wipers
Gcarlson
R-43 S
Hi,
Who knows where to find replacement wipers for the R25 outboard?
Gregg Carlson/"Bob"
The old spec I have for R25 OB wipers is the following
Wiper Motor 36111
Wiper Blade 14" 31114B
Wiper Arm 10-14" 33107A
It looks like discontinued, but Marinco has other 14 inch blades that probably are compatible
Hope that helps
It is the same the for R27 spec sheet as well, not sure which one you want as you have both 25 and 27 in your question
I contacted marinco
Quote:
That part number (31114B) is obsolete, and no longer manufactured. The closest alternative would be p/n 32014B. Ensure that your wiper arm uses a bayonet end. Hope this helps!
/Quote
Not sure if the if my arms are bayonet ends, so I will look that up too.
Cheers - dn
Followup from marinco-
Quote:
Hi Doug,
Our pleasure to help. 36111 is still a valid part number. If you’re using the wiper arm 33107A, it would be compatible with the blade p/n: 32014B.
Regards,
/Quote
