jimbeam
- Aug 21, 2019
- C-248 C
- FMLT2545G708
- waite & sea
When it rains moderate to hard I have water in the bilge coming from the aft starboard drain area below the rudder,
I found water even further starboard behind the locker in the extreme starboard aft section. A drain hole allows water into the aft section below the rudder piston area and then drains thru a hole to the bilge. For the life of me I cannot figure out where the water is coming in. The drain hoses are tight and not leaking, fittings on the stern like scuppers are tight. Maybe it's getting in further forward a bit on the starboard side. Anyone have any ideas where the water is coming from? It is a moderately significant amount, it activates the bilge pump. I was even thinking the drain plug but it seems only when it rains.
Frustrated
Jim
Frustrated
Jim
