Steering on 2013 R21 EC, Yanmar 3ym30
Stewartn
C-24 C (Sterndrive)
Had the boat almost 2 seasons. Seems to me there is excessive movement of the wheel while under way. Always seem to be correcting. Small adjustments, to be sure, but they're there. Is this normal? Can you tighten up the steering? Thx.
stewartn@optonline.net
If you go on line there are some videos and you-tubes of troubleshooting and adjustments of the teleflex cable steering that is installed on your boat. It's a real simple system but the rod that goes to the tiller can come loose and is located in a tight space access is through the deck plate starboard side fwd of fuel tank. If you need to replace the cable let me know as I have one in my shop you can have, I took it out when I installed a cockpit second steering station. Bob
