Stern Thruster Fuse Location
JeffreyAC77
2015 R31-CB (LE)
Lake Union, Washington
R-31 CB
FMLT3106E415
State of Mind
I do not know how to read an electrical drawing. I have a 2015 R31-CB (luxury edition). Where is/are the location for the stern thruster fuse(s)?
Based on standard installation procedures the fuse should be located close to the thruster battery. What you need to do is locate the positive terminal of the thruster battery and then follow the lead back towards the thruster. You will soon find the fuse.
Thanks. If there is more than one lead on the + terminal, how do I know which lead is for the stern thruster?
Ranger has placed the fuse between the stern thruster battery switch and the thruster. Start from there tracing the lead to the thruster. Alternately track back from the thruster end. The fuse will be in an enclosure labeled (Thruster). The switch will be labeled as well.
The fuse is a "big un" and not one of those small automotive blade fuses. It will be connected to a pretty heavy gauge red cable near the thruster service switch. GF
Hello,
Both of the thruster ANL fuses are located in the battery switch compartment, I believe at the bottom of the switches. They should be labeled with a clear plastic cover. Hope this helps.
Thanks all - will be checking for the fuse today.
Does generator start? It is powered from stern thruster. I had an internal thruster failure. It can be disassembled and same troubleshooting out of case as non -flameproof model. Had a bad thermal sensor inside motor housing.
