My thrusters have always worked unless drained batteries. Recently, stern thruster I noticed was NOT working -- on joysticks or remotely. Thought I had bad solenoid or moisture and chalked it off to getting a replacement. A few days later...I attempted to use the stern thruster again....this time it came on and would not stop until shutting off manual battery override.
My question? Could the reason it was not working and now working because of bad connection to stern thruster..perhaps getting moisture or corroded connections. I did have a problem with moisture in aft when power went dead on boat due to breaker switch from storm and even bilges were unable to work. And if it is simply a connection and/or corrosion issue....can I "dry" it out or reconnect power source to make it work normally again?
