Stern thruster
Karll
R-29 Classic
TBD
SEAduced
Just got back from a three day shrimping trip and discovered that my stern thruster works on the starboard but not on the port, any ideas what might be wrong?
Since it works one way but not the other, here's my two cents:
1. Check connections at the switch (for control circuitry): Aside from measuring current/voltage, switch around the connections and see if the issue moves
2. Check connection at the thruster (for control circuitry): same as above, sometime easier
3. Thruster circuitry itself: if you're handy with electronics and understand circuit board, go at it; if not, purchase a replacement circuit board and swap 1 for 1.
Obviously, you got power since one side works. In my opinion, it's not a power issue. It's either a control link broken, circuit board or the electric motor if all fails.
