SEA3PO
- Jun 27, 2017
- C-24 C
- Non-Fluid Motion Model
- Seahorse 21
- Kea
I have a Seahorse (brand) 21' tug..(1981) and I just replaced my Yanmar 3QM30 diesel with a new Universal Kubota 25 hp three cylinder.... no problem there...it is a much, much better engine...(half the weight...and quiet)
Once finished....I tried putting the boat in gear and heard a horrible noise...turned out to be the stern tube bushing (Johnson shaft tube bearing)... to replace it I have to pull the prop, driveshaft and coupler,,,Horrible job as I am in the mountains (Lake Almanor) and do not have access to proper pullers ...or anyone knowledgeable ......My question...
What would be the problem if I just made a driver that fits over the shaft and drove the bearing up onto the shaft further....and replaced the worn bearing with a new one....that would leave the old bearing free on the shaft...it would still be on the shaft but not loose enough to make noise...held by nothing so it could spin or do whatever it likes...(there is nothing in the stern tube)
Yes, I could do it properly but that will take me at least a week of work..most of which would be to get the driveshaft out....probably have to dig a deep hole in the ground to have enough clearance to get the shaft out...I can't lift the boat it is on a trailer and not high enough
I need ideas...opinions or jokes that will make me feel better
Joel Rapose
Kea
Lake Almanor...Kalifornia
Joel Rapose
Kea
