Lone Star Ranger
- Aug 24, 2010
- C-302 SC
- FMLT3109G516
- (2016) Lone Star Ranger II
So this past weekend I wanted to try to tackle the job of replacing the impeller on my own (with the help of my wife, Tracey) since I didn't have it done last year. 😱 I had a local marine shop in Annapolis replace it (or so I thought) in 2013.
So I'm going thru the steps of removing the panels in the "cave" to gain access to the front of the engine, and removing the face plate on the step so I can at least get one shoulder in and see what I need to do. Tracey and I removed the belt, and I start loosening the 4 bolts to remove the seawater pump. Of the four bolts, I can loosen the top bolts on the left and right side, as I try to remove the bolt on the lower left side, I realize that the bolt is stripped. I can't get my 6mm hex head to loosen the bolt because it won't hold on the bolt. :shock:
That's when I realize that I don't think the local shop actually changed my impeller in 2013, because had they been able to, the bolt shouldn't have been stripped; otherwise, how did they get the bolt back on? :x
So my question is, what do you recommend I do to get that bolt out? Normally, I would use a screw/bolt extractor, but that requires a drill, and we both know there's no room for a drill.
I'm sure I'm not the only tug owner who has encountered this issue, what advice/guidance can anyone provide. :cry:
