Last October I filled my fuel tank and filled the 30 gal fresh water tank. Today I was checking things to be ready for a small cruise tomorrow and came across the fresh water level dial showing empty (water pressure breaker was on). I ran the sink faucet a bit and plenty of water came out. I flushed the fresh water toilet and that was just fine. I rocked the boat side to side quite aggressively but the water level dial insisted on staying on Empty.
Hmmm, how can this be, as I'm sure I had filled the fresh water tank properly last October.
Well, in desperation to figure out what was wrong I decided to see if I could fill more water into the tank. So out with the hose pipe and by golly I was able to put around 10 to 15 gallons into the tank before the overfill started spurting.
Assuming that I did fill the fresh water tank last October properly and I'm sure I did as I use the water level dial on the console to sanity check the level and it was showing full as best I recall. So where on earth did the 10 to 15 gallons go I asked myself.
I checked the engine bilge and the midship bilge. There's always a bit of water in the engine bilge and the midship bilge was completely dry.
FYI... The boat is kept in water all year round in a covered slip.
Any ideas ?
BTW... no one had been sleeping on the boat between October and today... just in case you're wondering.
My guess is, that assuming there's no leaking from the fresh water tank, that even though I'm quite sure I had filled the tank last October, I simply must have not fill the tank properly.
Has this happened to anyone else ?
Thanks... 🙂
Any ideas ?
Thanks... 🙂
