rappja
- May 13, 2024
- Benecia, California
- R-31 CB
- Lily Marie II
I bought my 2019 R-31-CB about 6 months ago. I had a sea trial, then survey.
I have never had a power boat before. However, I have extensive experience with sailboats.
During the sea trial, the seller's broker and my broker were aboard. My broker, who is also a licensed captain, sort of took over. The owner's broker and I were basically passengers.
We noted that the autopilot wasn't working. The seller's broker contacted the seller, who told him something about which order the engine and instruments had to be turned on. I really didn't understand, but during the (second) sea trial part of the survey, the autopilot worked fine, after following the instructions. The surveyor didn't mention anything about the autopilot or the steering in his report. I bought the boat.
My broker and I drove the boat from where it was to my marina, about 30 miles. It was a blustery day, with choppy seas. I finally got to drive the boat, and noted that it was difficult to steer. Having never steered a power boat before, and given the choppy seas, I was unsure, but after playing with it a bit, we both decided there was something wrong with the steering. As I remember, we needed to put the wheel hard over to sort of engage the steering. The autopilot, however, steered perfectly.
I did some research (mainly here on this forum; search for Garmin autopilot), did some tests at the dock and decided it was probably a problem with the autopilot pump. My vintage R-31 is apparently known for this problem. The factory guys confirmed this. I found out about the bypass valve that Garmin produced to correct this problem (you can read about it on this forum). Also, newer models now have a different pump installed (called the SmartPump 2).
My Garmin dealer will not install the bypass valve. He considers it an inadequate solution. He thinks it requires the new pump. Also, the installation of the bypass valve will probably cost at least 50% as much as the new pump, so it probably makes sense to do it right. It will cost around $5000 (ouch!).
I disabled the autopilot as described in this forum, so the boat has steered well all this time since the purchase. I have not needed the autopilot yet. I have an appointment to bring it in next week to have the new pump installed, if that is in fact the problem.
So, my question is does the surveyor have any responsibility for missing this expensive issue which existed when I bought the boat? He did steer the boat, and could have found out about this known issue with some research. I want to be fair.
Also, I have the bypass valve which Garmin sent me for free, despite being out of warranty. I'll send it to anybody who needs it.
Thanks in advance for your advice.
