My post is concerned with the technique others employ to resume Autopilot navigation after having placed the Autopilot in "Stand by" mode.
When running with autopilot engaged and needing to take manual control to navigate around some object such as another boat in your way, weeds, floating log, avoiding collision situation with another boat, it's possible that after navigating around this object or situation the autopilot typically needs to be re-engaged. Now when wanting to re-engage the autopilot in most cases the boat will be 100s of feet off course and the boat's heading not aligned with the autopilots original course heading.
So what do others do to get back on course and engage the autopilot ?
I've found that simply re-engaging the autopilot the boat will dramatically and severely change course to get back on course. This in my opinion can be quite dangerous especially if care has not been taken to look around the boat to see if other objects have appeared etc. I've come to the conclusion I do not like the way the autopilot navigates back to the original course. Instead, my method is to use the chart plotter's calculated course display to steer the boat manually back to the original course even if it means a few extra minutes of my undivided attention. Once back on course to say within 20-30 feet and heading in correct direction I then re-engage the autopilot. This technique ensures my boat does not make the sudden and severe course correction when re-engaging the autopilot and gives me time to look about to make sure I'm not endangering my boat or other boats.
So, again I ask, what do others do when re-engaging the autopilot after having to place it in Stand-by mode to navigate around some situation as I mentioned above ?
