Table to sleeping area
gardehen25
C-248 C
We have a R-25. How do we make up the sleeping area in the spot the dining table is in? There seems to be some sort of button on the base of the table legs. There were no intructions of how to move the table.
It depends on the year. If it is a 2007 like ours, you lay down on the floor under the table and push in the two latches on the legs on the underside of the table and then wiggle off the table top and guide it over to one of the dinette seats. They you push the button on the base of the leg and twist/unscrew the legs from the floor. Drop the table into the groove/slot between the dinette seats and put the cushion on top. The newer boats have a single leg on a piston so it is no longer as convoluted to take down the table and make up the berth.
This topic has been discussed in detail before. R25's as late as 2009 still require wiggle science to remove; although R27s and R29s have a neat piston system. Check out: viewtopic.php?f=6&t=313&hilit=table
