LADYBUG TOO
- Dec 9, 2010
- C-288 C
- FMLT2916B909
- LADYBUG, TOO
The neutral safety switch on "Ladybug, Too" is very tender, touchy or whatever the correct technical term. Has anyone else experienced the same problem?? I did find that the aft cable anchor had not been installed correctly so I fixed that and adjusted the shifter link to make sure the neutral position was correct at the Teleflex unit. The electronic throttle has been adjusted for better "friction" so we are not getting throttle runaway anymore. Still, the shift linkage seems very stiff and is not affected by the throttle friction adjustment. I noted that later versions have a shift detent adjustment in the control head but not mine. I could not even find an 1800 series on the Teleflex site. Anyone have any suggestions??
Pat
Pat
