When I examine my Yanmar 4BY2-150 engine zincs after they have been in the engine for around 9 months I see that they are heavily scaled. Typically the scale material is a dull white in color and extremely hard and somewhat brittle. The scaling amount I've come across is close to 1/16" thick as best I ca measure it.
This brings me to the issue of scaling on underwater zincs for being affective once severe scaling thickness covers the zinc's surface area. I've not seen this to be a problem on the prop zinc nor the thruster zincs so far as the scaling seems to be non existent.
However, I have a large transom zinc plate (6"x8"), trim tab zincs and large ball zincs clamped to each of the swim step bracing legs. Scaling on these zincs is quite apparent.
I know that painting over say the trim tab zincs will make those zincs ineffective, so I'm thinking scaling will have the same affect.
I notice that the engine zincs if badly scaled can at times can be misleading in this respect as the zinc material can be eaten away internally even though scaled. This is evident by squeezing a badly scaled engine zinc between thumb and a finger and for it to completely collapse.
So I'm a little confused about concluding that badly scaled zincs are truly ineffective.
What are your thoughts ?
