Subject: The new R-27/OB's redesigned V-berth cushions/table
I've found that the new R-27/OB's previous V-berth center cushion and table have been re-designed. Overall the re-design is very good. The previous one piece center cushion that rested on the lowered table and its flip up/down extension has been replaced by two smaller cushions, and a one-piece table made slightly smaller and more rectangular rather than its 'weird' previous shape. This smaller table also sports two coffee mug holders on its aft end much like is done for the dinette table's isle side. The original V-berth's table was supported by a hydraulic piston pole (similar to the one used for the cabin's dinette table) and IMO gave the table much stability and for me was very easy to raise and lower..... This was a feature I originally admired for its simplicity for raising and lowering the table.... Now, to my surprise 😱 this previous hydraulic pole has now been replaced 🙁 with a single piece pole (similar to the one used for the cockpit's table) and to lower or have the table raised one must manually removed the pole or re-install it as required. I'm told by RT this one piece pole will actually be better as the hydraulic piston pole was a bit awkward at times for raising the table up. Not really having any experience with these hydraulic type poles I have no opinion about the difference between having hydraulic vs. single fixed length pole for the table.
Of course, the boat will be equipped with two such table supporting poles; one for the V-berth's table and one for the cockpit's table. This IMO is a necessity as we will be having both the V-berth's and cockpit's table raised/installed at the same time quite frequently.
Given that there's mention that the hydraulic piston pole could be or can be awkward for being raised (not from my experience mind you), can others pitch in here and post their experiences with this issue I've been informed about ? Thanks.
I guess one of the advantages of having a single fixed removable pole for the V-berth's table will allow the pole and table to be stowed elsewhere making for a useful gangway/isle between the port and starboard V-berth bunks without having the fixed collapsed hydraulic pole in the way.
