GOrdy
- Feb 26, 2025
- R-29 Classic
- Gordon Feenstra
Unable to apply throttle in neutral, it always shifts into gear. No need to do this but it was noted on the last survey.
2011 R29 with Teleflex throttle
When I remove the rubber plug at the center of the shifter I am able to insert a small screwdriver and depress something springy. Then it allows me to apply throttle in reverse (still not forward) without shifting. Should there be something under the plug to allow this? Seems the right size bolt could work? Or is this normal.
