Lake Effect
- Jul 8, 2011
- R-25 (Outboard)
- Non-Fluid Motion Model
- C Dory 25
- Lake Effect
I am the new owner of a 2021 RT25LE. I recently experienced a reduction in function of my thruster. The battery tested lower voltage. Upon examination, I observed the thruster battery was not grounded. A check with the factory schematic showed the cable from the thruster battery negative to the engine ground had been removed. I inquired and received verification the thruster battery is required to be grounded with all other batteries. I added the ground cable. The thruster battery was then being charged.
However, here is the problem. The house battery bank began showing a 6A discharge to the thruster battery. At first I thought little of that but became concerned after 12 hours of continuous discharge and the house bank being reduced from 100% to 82% with mostly full sun solar exposure. The thruster battery was showing full charge yet was still being charged from the house bank.
I didn’t feel I could let the house bank completely discharge so unhooked the negative from the shunt. This of course stopped the discharge.
Is the thruster battery even supposed to be charged from the house bank? Do I have an ACR not working properly?
I think this problem is why someone had removed the ground cable from the thruster battery previously. To stop the continuous house bank discharge.
