GaylesFaerie
- Jul 20, 2020
- C-28
- FMLT2701D112
- Gayles Faerie
Both of the thruster fuses on my 2012 R27 are looking pretty tired and I want to be prepared in case they blow or break assuming they are 10 years old. They are both rated at 150A but they don't look like the other large ANL fuses for the engine (100A), genset (150A), or inverter (175A) - see pictures below.
Thrusters:
https://share.icloud.com/photos/028v6yM ... m5IcCfLcSg
https://share.icloud.com/photos/05eDvrW ... ruFgpe-4DQ
Inverter:
https://share.icloud.com/photos/088Jm3F ... 1ReAVkppRw
The thruster fuses appear to be encased in ceramic while the others use what looks like computer board. The ceramic on the bow thruster is actually loose and can be wiggled a bit although the fuse itself appears intact and I did not have any issues using the thruster last season.
Can the thruster fuses be replaced with ANL fuses similar in construction to the engine and inverter fuses provided they are appropriately rated?
Thanks, Gary
Thrusters:
Inverter:
Thanks, Gary
