Thruster R27OB
Bob&Jilly
Fargher Lake WA
FMLT2757*818
Lynnsanity II
Shake down day so as I am approaching a dock windy and lots of current bow facing the dock no thruster. The little light by the toggle switch comes on and I get a clicking sound but that's it. Is this a fuse issue?
Try the remote for thruster if your boat has one. In my boat there is a switch to turn thruster remote on. If remote or joy stick doesn't work, then check wires at thruster. I had a corroded wire at the thruster. Soaked wire terminal in vinegar and thruster worked again. I am assuming if you heard a click that your rotary master thruster switch is on.
, I will check the fuse first- if that is OK and the battery is charged I will check the thruster Thanks so much!
