Levitation
- Aug 12, 2009
- C-248 C
- fmlt2510f809
- Charlotte Ann
I had the 110 volts shut off to the boat for a while, ~ 2 weeks... Happened to check the battery voltages two days ago and the #2 position showed only 9.7 volts (arggghhhh)
Long story short - pun intended - found a steady drain of 1400 ohms on the thruster battery (8.5 milliamps)... While this is not much it is 1400 more than tolerable...
1: In the process of trying to puzzle this out I discovered the #2 position on the battery voltage switch is the thruster not the house battery as the manual claims...
2: Discovered the rear thruster is the culprit... There is no current drain on the cable run to the front thruster...
3: Discovered the rear thruster is a real bare to get at...
4: I do not see any connection to that positive cable leading off to other equipment... As best I can tell this thruster is the 'sealed' variety as the cable goes directly through a rubber grommet in the motor case...
Is this low grade 'short circuit" in the thruster a known problem? The thruster does run in both directions and sounds the same as the front thruster...
I let the Promarine boat charger bring the thruster battery back up for 24 hours ... I just load tested that battery minutes ago and it shows as weak... I unhooked the boat charger (I am becoming less and less fond of that Promarine unit) and dragged the big charger I use in the shop for the bulldozers, etc. (70 pounds) up the ladder into the cockpit (I may need another operation soon) and it is currently stuffing 35 amps into the battery... I will give it a good equalizing charge and test it again, but I suspect it is a goner (kiss another $200 bill goodbye - double arrrggghhhh)
5: Discovered the Promarine charger ignored the load test on the thruster battery and continued to insist that it was fully charged and floating after the load was removed... (did I mention I am becoming less than fond of this unit?)
