Timed Bilge Pump Not Automatically Running
mlanger
Malaga, WA
Website
www.mygreatloopadventure.com
R-29 CB
Do It Now
I have a 2019 R-29 CB with one of the 6-minute (I think) timed bilge pumps installed. Recently, it stopped running automatically. It does run, however, when I turn it on manually with the switch at the helm.
Is the bilge pump broken and requiring replacement or are there some troubleshooting steps I can follow to revive the timer?
Good morning M, the RULE bilge pumps should cycle every 2.5 minutes or so. If not doing, check the 7.5A blade fuses located on your 24-7 fuse panel (typically located in the midberth on the R29's). If the fuse is okay, then it could be an internal issue with the pump, or the connections there at the pump.
Thank you,
-Tim
