Tires
davecook
FMLT2721A313
Had my I st blow out -3 yr old st225/75r15 E range Carlise on my R27 , I will replace all of them , anyone use anything better than the Carlises ? Thanks
I have not been happy with any of the ST tires. My last pair of ST's were Goodyear Marathons and while the seemed to perform better than the Carlisle's they still did not last more than 8,000 miles on a light 2,000 pound gross weight trailer.
My new trailer for the R25 came with four LT235/80R16D light truck tires which have a load rating of 2,633 pounds. With 2,000 miles on them in 10 months I am pretty pleased so far. My next tires will probably be the Michelin XPS RIB LT235/85R16E tires with a 3,000+ pound load rating.
LT tires in general do not have as stiff a sidewall or the load rating of ST tires. You have to shop carefully and consider load ratings, tire width, tire height, max tire pressure amount other factors.
Here's an excellent article by Mark Polk about LT vs ST tires that summarizes the choices:
"let me begin by saying when it comes to the type of tires to use on a travel trailer or 5th wheel trailer I think there is a lack of information and understanding on the topic. If you head over to the RV forums and type in “ST vs. LT tires” be prepared for a good deal of debate and varying opinions. I can quite honestly say that regardless of how well this article explains the information lots of folks will continue to embrace their original opinions. It’s one of those controversial subjects like gas vs. diesel. My goal with this article is to attempt to clear up some of the confusion on this topic so RV consumers can make an educated buying decision.
Before going any further let’s take a look at what the ST and LT tire designations actually mean.
ST tire designation: ST stands for Special Trailer tire. ST tires are designed for use on trailer axle positions only. They are not designed for the load or traction requirements of a drive or steering axle. ST tires have strengthened sidewalls to prevent the tire from rolling under the rim in turns and when cornering. All ST tires have a maximum speed rating of 65 mph. ST tires feature materials and construction designed to meet the higher load requirements and demands trailer towing presents.
Tim Fry, senior development engineer with Goodyear Tire & Rubber Company stated, “The major difference is reflected in the polyester cords used in ST tires. These cords are bigger than they would be for a comparable P or LT tire. Typically, the steel wire also has a larger diameter or greater tensile strength to meet the additional load requirements. Because of the heavier construction for an equal volume of air space, an ST tire is designated to carry more load than a P or LT tire.”
LT tire designation: LT stands for Light Truck tire. One definition at http://www.tiresafety.com defines an LT tire as any tire line or size which would typically be applied on a light truck (SUV, pickup, van). As such it could be an LT-metric tire for use on a one-ton truck or a P-metric ‘light truck’ size of a typical tire used on an SUV. Light trucks (pickups) and SUVs differ from standard passenger cars in their overall strength, load carrying capacity, center of gravity, and driveline complexity. For this reason, the tire options for light trucks and SUVs are often more complex than passenger cars. Factors such as load range, ply rating and sizes vary greatly from those of passenger car applications.
These are just definitions to provide a basic understanding of what the ST and LT tire designations mean. Please hold back from any debate until you read the rest of the article. Now let’s dig a little deeper.
If you do visit some of the RV forums, and/or research the topic on the internet you will quickly surmise much of the debate concerning ST vs. LT tires centers around some of the following issues and concerns:
Chinese manufactured ST tires
ST tire blowouts on trailers
ST tire speed ratings
ST tire life expectancy
At this point it probably makes sense to address each of these concerns separately.
Chinese Manufactured ST Tires:
I would like to begin by saying I do not like the issues U.S. manufacturers are confronted with when it comes to dealing with Chinese made goods. The Chinese continue to devalue their currency, resulting in unfair trade practices, and in my opinion our government lacks in taking measures to prevent this from happening. Unfortunately RV manufacturers are extremely cost conscious and more often than not opt to use less expensive products in manufacturing units.
Several years ago it was discovered that numerous brands of Chinese manufactured LT and ST tires had defects that resulted in premature tire failure. RV owners towing travel trailers and 5th wheel trailers were experiencing excessive tire blowouts and other tire failures long before the tire’s life expectancy was reached.
It’s too bad, but lots of reputable U.S. tire manufacturers are producing tires in China to lower costs and remain competitive in the marketplace. But, these U.S. brand tires are built with the same quality and specifications a tire manufactured in the U.S. is built to. The defective Chinese tire fiasco, from say 2005 to 2008, left a bad taste with RV owners and many resorted to replacing their ST tires with LT tires. Despite my feeling towards all things Chinese, it seems that U.S. brand tires manufactured in China since 2010 have been fine. This does not however apply to any of cheap priced Chinese brand ST tires being exported to the U.S.
ST Tire Blowouts:
When I talk about ST tire blowouts I am not referring to what we just discussed referencing the defective Chinese tires. In a nutshell most trailer tire blowouts are not a result of ‘bad or inferior’ tires, they are a result of one or more of the following conditions.
Overloaded tires. Every tire manufactured has a load rating based on the tire’s inflation pressure. A tire’s maximum load is the most weight the tire is designed to support at the inflated pressure. ST tires have some of the highest load ratings. This is one of the reasons they are designated for use on trailers. Truck and automobile tires do not have to withstand the weight and stress that is put on trailer tires. The only way to know if a tire is overloaded is to weigh the trailer by individual wheel position. It is quite possible to weigh an axle and be within the axle weight rating, but when the tire positions on each axle end are weighed separately a tire rating can be overloaded.
Over & under-inflated tires. Another culprit for tire blowouts is over & under-inflated tires. Failure to maintain the correct tire pressure for the load can result in fast tread wear, uneven wear and poor handling which can all lead to tire failure. Remember, the load rating for a tire is only accurate if the tire is properly inflated for the load. Under-inflated tires cause extreme heat buildup that leads to tire failure. Tire manufacturers publish tire load and inflation tables with information on the correct tire inflation pressure for the load. A big reason tires fail is they are not properly inflated for the load. The appearance of the tire can look normal on the outside, but the internal damage is not visible. Tires with internal damage caused by under- inflation can fail catastrophically without warning. One thought is to inflate the tires to the maximum ‘cold’ pressure found on the tires sidewall if you don’t know the exact load on the tires, or the exact weight of the trailer. This should not however serve as an excuse to not weigh the trailer.
Improper weight distribution. When a manufacturer builds an RV weight distribution is critical. The weight from front- to-back and side-to-side must be carefully considered to avoid having too much tongue weight, too little tongue weight and/or too much weight placed on the trailer’s tires. The manufacturer did its job distributing the weight when the unit was built, now the RV owner must do their job by properly distributing any weight added to the trailer. Some tire overload conditions can be corrected by distributing the weight in the RV, but you still need to weigh the RV by individual wheel position to make sure there is not an overload condition.
ST Tire Speed Ratings:
All ST tires are rated for a maximum speed of 65mph. When you travel at speeds higher than a tire is rated for it will eventually fail. The heat that builds up in the tire results in fatigue and tire failure.
Here is some additional information taken from a Goodyear Tire & Rubber Company Product Service Bulletin, PSB #2011-13.
This bulletin provides important information to help your customers obtain the best performance from “Special Trailer” tires. Please review the following important points with your trailer tire customers. Special Trailer (“ST”) Tires: Goodyear Marathon trailer tires are widely used in a variety of towable trailer applications and are designed and branded as “ST” (Special Trailer) tires. Industry standards dictate that tires with the ST designation are speed rated at 65 MPH (104 km/h) under normal inflation and load conditions. Based on these industry standards, if tires with the ST designation are used at speeds between 66 and 75 mph (106 km/h and 121 km/h), it is necessary to increase the cold inflation pressure by 10 psi (69 kPa) above the recommended pressure for the rated maximum load.
Increasing the inflation pressure by 10 psi (69 kPa) does not provide any additional load carrying capacity.
Do not exceed the maximum pressure for the wheel.
If the maximum pressure for the wheel prohibits the increase of air pressure, then the maximum speed must be restricted to 65 mph (104 km/h).
The cold inflation pressure must not exceed 10 psi (69 kPa) beyond the inflation specified for the maximum load of the tire.
ST Tire Life Expectancy:
It is quite possible for a tire to wear from the inside out. What this means is you cannot see the tire’s internal wear and fatigue and without warning you have a blowout when you least expect it. I mentioned a moment ago that under-inflated tires cause excessive heat resulting in tire failure. The same is true of an over-inflated tire when it comes in contact with pot holes, curbs and other common obstacles found on and alongside the highway. It is totally unrealistic for RV owners to expect ST trailer tires to last as long as P or LT tires do. ST tires are subjected to more weight, more sidewall stress and more user related tire issues, so it’s only natural they won’t perform as long as automobile tires.
If you think about it, with the exception of defective tires, all of these factors that increase the chance of tire blowouts are within the RV owner’s control. If you take the steps required to avoid these tire related problems it is quite likely you will not experience abnormal tire blowouts on your trailer.
LT vs. ST Tires:
I mentioned earlier that lots of trailer owners made the decision to switch from ST tires to LT tires for use on their travel trailer or 5th wheel trailer. Two popular and well built LT tires that come up in discussions as replacement tires for ST tires are Goodyear G614 235/85R16 and Michelin XPS RIB LT235/85R16E tires. If you make the decision to switch to LT tires I caution you to make absolutely sure the tire you choose meets the application criteria required for use on your travel trailer or 5th wheel trailer.
Light Truck tires are not always the same size, and do not always have the same load carrying capacity as ST tires. Depending on your trailer’s axle weight rating the tire load capacity might be 3420# @ 80 psi for example. The Michelin XPS RIB LT235/85R16E tire load capacity is 3,042# @ 80 psi. If you switch to LT tires for trailer applications the tire inflation pressure and/or the size of the tires would need to be capable of matching the load capacities of the trailer. If the size of the tire is increased to compensate for load capacities there needs to be sufficient clearance for the larger tires. Cost can be prohibitive too when you not only consider purchasing new tires but larger wheels for the tires to go on.
There are other considerations as well. One is that ST tires are designed for a limited amount of rolling resistance, whereas LT tire construction must address the tire’s traction attributes which can increase the rolling resistance. Tires have other ratings too, like Mud & Snow, Summer Tire, All Season etc. For example, Michelin XPS RIB LT235/85R16E tires are rated as highway summer tires, meaning they won’t perform as well in colder winter climates.
It is my general consensus that brand name ST tires matched for the application and properly inflated, maintained and not overloaded are the right tire for the job. I personally only use Michelin tires on my automobiles and motorhome, but the tires are designed for the application. My point is if you are thinking about making the switch from ST to LT tires for use on your trailer don’t get caught up in marketing propaganda; look at the engineering and tire application facts before spending your money on the wrong tire for the job."
Happy RV Learning,
Mark Polk
http://www.rveducation101.com
Interesting article....however, I just purchased two Provider ST225/75R15 tires, load range D (2540 lbs @ 65 psi) with a speed rating M...( max speed 81 mph). That speed rating is considerably higher than the article' stating "All ST tires are rated for a maximum speed of 65 mph."
Getting back to Dave's original question, the choices for a 15 inch ST tire with an E load range are pretty limited. The big 3"most commonly used are Carlisle Radial Trail, Goodyear Marathon and Power King Tow Max (aka "Blow Max") in that ST225/75/15 tire size. This is just my experience but I would choose the Goodyear Marathons out of those three. But the Marathons are not perfect with lots of owner complaints of low life, tread separation and blow outs.
Our very heavy loaded trailers really should be coming with at least 16 inch wheels. Just because there are E load range trailer tires in 15 inch size that have load ranges over 3,000 pounds doesn't mean that using 15 inch wheels is an optimal choice. A 16 inch or even 17 inch wheel on a trailer gives you a much wider range of tire options for towing safely.
And yes, some of the newer ST tires have speed ratings over 65 mph. The article is a couple of years old but I still found it valuable in making my trailer tire purchasing decisions.
Thanks for posting that article - very informative.
Pearl of wisdom. When purchasing a trailer tire check the date of manufacture BEFORE it's mounted on the rim. Trailer tires should be replaced every 5 YEARS regardless of mileage. There is a DOT code on every tire. The last 4 digits of the DOT show when a tire was manufactured. The first 2 digits are the week of the year; the last 2 digits the year (0116 would be the FIRST WEEK OF 2016). Unscrupulous tire dealers may try to sell you a tire they've had sitting in their warehouse manufactured a year or more ago. That time counts toward the 5 year AGE limit shortening the time you can actually use the tire.
caveat emptor
Capt'nKarl
I heard from several sources that trailer tires should be replaced every 5 years based on age, not on tread wear. My Float On trailer is 6 years old and travels 150 miles in the spring and 150 miles in the fall. It is stored year round in a heated garage and the tires look brand new in every way.....no indication of any deterioration. I have no plans to replace them in the near future.
Phil
Phil
Phil,
My opinion is that at 150 miles each way and the way you store your boat you will get far more years out of the tires than most trailer tires. Towing just 150 miles, even if they were to fail, you are close enough to home to resolve flat or blowout issues.
By the way, in preparation for my trip cross country (4,000 miles one way) I bought Maxxis Tires. After doing extensive searches they got consistent good reviews. I had no issues going cross country. Hoping the same is true on my return trip in September.
Tires rot from the inside out as well as outside in. A tire may look new on the outside but can be a mile or a minute away from rupture. We make decisions and take risks everyday on what to we work on and what we monitor. I relate buying new tires to the routine maintenance of the engine we rely on. The oil, filters and impellers look fine but we change them because we know it's a prudent thing to do. Although there is no guarantee any tire new or used can't fail I'll take the recommendations of experts when it comes to recommended changing frequency.
Be safe and carry a spare!
Speaking of changing frequency, could help thinking about a quote from the late Robin Williams
Politicians and diapers should be changed frequently and for the same reason
I confess to be not being a tire expert so take this experience at your own risk: My tow vehicle and boat and trailer spend most of their lives in the garage and I push the 5 year rule for tire replacement to 7 years. (Maybe I have been lucky but it has worked for me and just seems wasteful to throw away what look like very good tires with more than half their tread.) Last year when I was contemplating new truck tires at 8.5 yrs (just did not get it done in 7) I broke a belt in a rear tire towing the Ranger Home from its maiden voyage. No damage, but a big bulge in the tire. I believe the rot from the inside out explanation, because from the outside they looked fine. I have friends that have left their trailer outside parked on the ground (i.e. gravel or dirt) without covers on the tires and have had consistent tire failure in less than 3 years.
I have Maxxis tires on two tandem axle trailers. They make several 250-mile trips each summer. So far, so good.
Thanks for all the replies , we just got a marina after 5 days out on the hook . They all where good info
I used ST tires with an H rating inflated to 105 cold pressure, about St Louis replaced the rubber valve stems which were leaking with steel stems, I have gone about 5000 miles and will put that same mileage when I return to Florida, but I am hauling 12800 lbs on my R27, presently in Prince Rupert loading the boat for the Roche Harbor Rally.
I'm not sure but I have come to believe the ST rating on trailer tires stands for Sh-tty tire. We too switched to Michelin XPS ribs as a previous poster mentioned. We are happy with them so far. They even seem to ride better the Gonna Pop Chinese Radials they replaced. We always get our trailer tires balanced. We use Michelins on the truck also and have had good luck with them. We check tire pressures religiously. Every stop I touch the hubs with my two fore fingers and lay my hand on each one of the tires. That can tell you a lot too hot to touch spells trouble. The sunny side will always run a little hotter. Some use infra red heat reading guns to check hub and tire temperatures. Safe Travels
