Toilet R29
Irish Mist
C-288 C
FMLT2922K011
Just wanted to share as I'm sure there is more then me that may not read manuals
I was concerned about all the water the electric toilet uses. It fills with water and flushes twice. I learned if you hold both buttons at the same time it will just flush no water. I just push "add water" button to have a bit in the bottom after the bowel is empty Saves one fill cycle... This is just for #1 If you try this with #2 you may have problems
I do not know about the 29, but the 27 has a fairly long mostly level run from the toilet to the tank. My advice is to use plenty of water with flushes. This helps keep mostly clear water in the line to the holding tank. I know you will pump out more often, but you do not want to see what happens when the toilet quits with anything but clear water in this line. Do not ask me how I know. :roll:
You make a good point
