On my 31CB, the upper helm shows a lot of play--5 turns lock-to-lock. The lower helm is fine. Fluid level at the upper fill cap looks fine, but I'm sure there is air in the system. Any guidance an how t fix/bleed? Thanks.
I had the same issue a while back. i opened the upper helm nut and did several back to back full turns. Added fluid until all the gears were clearly covered. And then repeated the lock to lock several more times. Seemed to clear the system.
