Torqeedo battery charging LED anomaly
baz
I've started to see an anomaly associated with charging our Torqeedo motor's battery.
Typically, when charging the battery via the supplied charger the LED will blink until the battery reaches 100% at which point it stays lit. However, lately (maybe over past year now) I've noticed that when the battery is fully charged and I remove the charger connection from the battery the LED will start blinking again. This confuses me. So I attach the tiller arm to get a battery charge level readout and it display 100%.
If I leave the battery without the charger attached over night I find the LED is still blinking. 😱
Just to be sure I reattach the charger briefly and then disconnect it and the lED stops blinking.
Very weird IMO.
I called Torqeedo service Dept the other day and discussed this. I was told that the software in the battery probably has a bug and would need to be updated. My battery is over 3 years old and is out of warranty, so if I wanted I had two options
1) Send battery to Torqeedo to have the software updated
2) Replace the battery with a newer model
I told Torqeedo service that I can stop the LED blinking issue if I reconnected the charger for a very brief period and then disconnect it. They said, so long as I could do this then any battery drain due to the blinking LED should be eliminated and not to worry.
I asked about battery life as part of the discussion and was told under normal use I should be able to get 6 years with the battery. At this point the battery could be down to around 75% of its new condition. Torqeedo has not had the batteries out in the market for long enough to be more precise and that this 6 year statement is what the battery cell manufacturer Sony tells them. Keeping the battery well maintained should provide an extended life of around 8 years maybe.
A new battery will cost $699, and is one that has a greater battery charge life (not sure about the terminology here).
I asked about recycling the old battery when the time came to replace it. They had no real good answer but did say, when that time arrived to give them a call and they would assist with the recycling.
So, it seems all is AOK so long as my simple method for stopping the LED from blinking after a full charge continues to work.
I have no idea to what extent the blinking LED would deplete the battery charge more quickly than if the LED was 'blank' (not lit).
I asked Torqeedo if they had other customers with a similar issue and was told, yes they had but very few.
Torqeedo was convinced the issue is software related.
Have others with the Torqeedo motor/battery observed this blinking LED issue I wonder ?
