Gypsy
- Jan 16, 2021
- R-21 EC
- USFMLC2804F
- Gypsy
I made two improvements to my trailer that I feel are worth sharing.
The first has to do with the bunks. The rug material that comes on the trailer bunks doesn't allow the boat to slide off the trailer when launching, and it doesn't allow the boat to slide up on the trailer when loading the boat. To remedy this problem, I added plastic slides to the bunks. The plastic I used is not your run of the mill PVC. It is called Natural Virgin Uhmw Plastic. It is very hard, it can be machined, and it is extremely slippery. Also, it is expensive. I think it might be the plastic that is used to make artificial ice skating rinks. I have read in Tugnuts that often when one retrieve ones boat and the trailer is on level ground, the bow is not tight against the winch stop. This should no longer be a problem. I haven't tried it, but I feel you should be able to winch the boat up tight on level ground with little effort. The plastic came from Emco Industrial Plastic - phone #(973) 559-8062. I bought a 4'x8' x 1/2"sheet. It cost $455 and about $120 to ship. I still have enough left over to line my tandem jet ski trailer. See photo.
gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=80302&g2_serialNumber=1
The second improvement has to do with lining up the boat when powering on the trailer. From the helm, I can't see the winch, so I is difficult to know if you are lined up correctly. I added a radio antenna pole by the winch. I can now easily line up the boat and also know when I am up against the stop. See photo.
gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=80304&g2_serialNumber=1
I feel I can, if necessary, load and unload the boat single handily.
